Help!!! Need stock tune hp tuners file for my 2012 ve clubsport e3 manual
stimutation
morayfield
ve clubsport r8
Hi to all,
Is there anyone out there that has a stock tune file on hp tuners?
Need help asap as I need the stock file to load back into car.
Thanks.
07GTS
Australia
VEGTS BUILT BLOWN E85
when u first read the vcm it makes u save the file and u shouldn't change that one only modify it and save to a different name, can look at the hptuners tune files for one and hope it's right, what is the issue..?
JETURBO
40
ADELAIDE
VF R8 SV
I think i got one, stuffed in with a billion other tune files, ill have a geez for you and buzz u a pm ok
stimutation
morayfield
ve clubsport r8
Has anyone got a stock tune file for hp tuners as I still need one. The car that I've just got has a tune and not running right. Not sure who the tuner was. That is why is I need a stock file to put it back in and start again.
Thanks.
07GTS
Australia
have a search on the hptuners tune deposits see if one is there, can u put the tune up so we can look at it see if anything looks odd...
07GTS
Australia
whats the actual fault with the way it runs..?
pagantavarez
41
republica dominicana
files
Hola quin puede ofrecerme un paquete de archivo. soy nuevo y necesito una base de datos de archivos de ecu para hptuners
hjtrbo
Donating Member
FG XR6T / HJ Ute / VF2 R8
Hola, el sitio web de sintonizadores HP tiene una variedad de archivos para descargar para aplicaciones estándar. Necesita una cuenta y un dispositivo MPVI válido para acceder al repositorio de melodías. Para melodías modificadas, sé que si no hay un archivo, deberá visitar el foro de sintonizadores de HP y buscar archivos. Espero que esto ayude.
