The bonnet is out of alignment and does not shut flush on the left hand side
Because of above, the corner of bonnet has cracked the windscreen
As you dont sound to mechaniacll inclined, i suggest a panel beaters to correct the alignemnt
The stereo/tape deck has been removed and put back in and now it doesnt work...even the clock
You need to reenter you PIN code for you head unit. If you ring you holden dealership they can provide you witht he number and it will work again. Its a securty code protection system.
the plate that goes underneath the thingy that holds the bonnet up is missing but i have found the screws..yeah!
Im sorry but i have no idea what your talking about with this one!
interior light doesnt go on
Is the globe ok? Fuse (drop pannel under steering coloumb) ok? does the dome switch turn it on?
air conditioning only works on full setting and is VERY loud
Air con only usually works on 2 or above... not sure about a/c sorry!
You need a new one! Auto barn or supre cheap have replacments. It requirs you to take the passenger side wheel off. Not hard but dedious.
the clips that hold both sun visors on are broken
You will need new ones also. They smply screw off with a phillips head screw driver. Wreckers are your best bet.
panel under the steering wheel keeps coming off
Ensure the surclips (plastic things with a think gruve on them) are in and secure. They turn to tighten. Also insure it is hinged at both the left and right corners.
right windscreen wiper is broken
Which part? Wiper Blade?, arm?, motor?
drivers side door sometimes doesnt lock
Central locking im guessing? Its an actuator problem. Check it by takin off the door trim an locking and unlocking it a few times. It may just be snagged or its dying.... a wrecks will sort you out a new one!
which part? replacements are about 10-20bucks depending on elec vs. manual from a wreckers. Not hard to replace.
broken right headlight cover
New one needed, see wreckers.
hahahaha welcome to commodores! common fault, can be fixed by re-soldering the dry solder joints but unless you want to pay someone to do it, its not a DIY for the uneducated.
car very quickly overheats when started and stopped a few times
Is your thermo fan working? Like at idel at about halfway, does a fan kick in? Get a service and compression test done to ensure you dont have a blown head gasket. A blocked thermostat, poor coolant or coolant blockage can also cause these issues.
seat adjuster knob missing on front left seat
Wreckers, $5
bumper coming lose on right side
The bumber has 4 bolts and two guide clips. The panel has come unlciped or the clips have broken... get the panel beater to do it when he does your bonnet.
aZk.
