lmoengnr
Donating Member
- Jan 15, 2012
- 6,991
- 46,028
- 113
- Location
- Sunbury Vic.
- MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Mass Air Flow sensor.Ok I’ll do that. What is maf?
I think I found something reading the workshop manual does this help?You can buy some Mass Airflow sensor cleaner. That’s something you can do. Clean it by spraying it. Have to remove it though. 7mm socket to loosen the hose clamps that hold it in. Be careful with it. Don’t touch the inside. Spray the cleaner in and let it dry. Reinstall.
Might help the sensor work better.
Where is the plug located?Our VE gets voltage drop to the MAF. It’s the plug. The MAF is a mAchTeR and the plug doesn’t sit quite right compared with a genuine one. Wiggle the plug and the 5v reference comes good. It’s cable tied up to firm up the plug and problem sorted.
