TAHAIC
- Apr 23, 2016
- 5
- 0
- 1
- Location
- Brisbane
- VZ Commodore LE0 Alloytech 175kW
I've just done a bunch of work to my car lately but still have high full consumption. I have replaced fuel injectors, fuel filter, spark plugs, lower inlet manifold gasket, upper inlet manifold/plenum gasket, O2 sensors (LE0 motor only has 2 precat 4 wire), thermostat and housing, front water pipe gasket, removed and resealed front timing cover, checked timing chains - good, new oil and coolant, reset ECU. It is running great and using less fuel than it was originally approx 15lt/100km now down to 13.6lt/100km but I think that is still high for this car. Consumption rate is a mix of highway and city driving.
I was wondering if there is anything that can be done to reduce it such as taking it to Holden (or preferably someone else) so they can lean it out via ECU programming - is this possible? Or is there anything else that can be done to improve economy? Any and All help is appreciated - thanks
