GRPAVL
- Jul 1, 2013
- 78
- 0
- 0
- Location
- Auckland, NZ
- Website
- homepages.ihug.co.nz
- 1987 VL Calais Walkinshaw
I have 2 problems but first a run down, car is a vl calais now running a holden 304 v8 (as per my sig).
I originally thought that I had a dodgy oil pump as it wouldnt presurise after being rebuilt. After repacking it numerous times with vaso the oil lamp finally went out ..... now it wont turn back on .... ever.
When I have the key turned to on the oil light on the dash doesnt turn on though i do get engine check etc etc. There is no way it can have pressure while its not running.
I spliced the wire that runs from the oil pressure switch to the dash light and with the key still on shorted the end to earth. the lamp come on so thats fine and working as expected. Next I checked the orange wire had 12v which it did, and the purple wire has 12v when the fuel pump was working which it did. So I know the wires are ok but the oil sender doesnt seem to work. Is this a common thing for the 304?
Thinking that I may have damaged the engine by running it with no oil I removed the oil sender and replaced it with the sender from my old rb30 vl engine (via and adapter to fit the block). Luckily I still had the old oil sender wire so I reconnected that up. When I turned the key to on the oil pressure gauge wiggled bit to low, when I cranked it, it started up and almost instantly the gauge was fluctuating depending on the revs i gave it.
At this stage I was pretty sure my oil pressure sender unit was pooped but I decided to whip a rocker cover off just to check there was oil around the rockers etc. To my horror it was a little slimy but I would have expected to see more oil than that. I then got the wife to crank it for a second and the oil pressure gauge was working but I had no oil coming out the lifters to soak the rocker rails.
HELP ... what could be wrong and how do i fix it ....
Q
Q
