Put the halo's in yourself... Im in the process of installing red halo's on my VE SSV.
My Halo light install... Red Halo's as it matches the red interior dash lights ect... Finished the fogs, Halo's wired in with the foglight switch just for now... Very rarely use the halo's but will look the part once its all finished.
I had planned to install halo's around every light including the tail lights... But.... 5 minutes to long in the oven and this is the result.... I bought another pair and tried for hours to dismantle the other side without success, If anyone gets the same idea dont even try its impossible.
The headlights on the otherhand 10 minutes 100c in the oven was enough to soften the glue and with a little effort came apart easy.... However i searched the net for hours and hours looking for the correct size halo's to order and had no luck not one site gave me the sizes only small medium and large, Great help that was so i ended up getting the tape measure out and came up short with the high beam halo's... The pair i ordered for the high beams were 20mm to small and didnt look right so im waiting on the correct size to arrive before i can finish....
I received the correct size halo's today so i will be getting to work on the scary job of heating and dismantling the front headlights for the install...
If you are going to do it yourself dont take your eyes off your lights while in the oven or they may end up light my tail light did, Its not hard its just a bit of messing around.
As i mentioned i spent hours searching the net for the correct size halo's to order and couldnt find one mention anywhere, I may as well help the next person out who might search for the sizes...
VE SSV projector style head light Halo sizes
Fog lights - 70mm
Head light projector - 90mm
Head light high beam - 140mm.... Stupid me ordered 120mm Doh...
For anyone who may be interested in attempting to dismantle the tail lights, I highly advise against this as unlike the head lights thats been glued in the tail lights have been pressed into the casing while heated.
Tail lights 90mm
Hope this helps someone, I cant wait till my ve rolls around with devil eyes...
