How hot is your vt????
11gothevt11
99 VT Sedan
hi there
How hot does your vt normaly run?????
Do you have thermosat??
Do you have old radiator???
Mine normal under half way but when weather is 35 degrees its goten upto 3/4
I don't have thermosat and i changed coolant and radiator cap
I need to know as the last thing i want my engine to boil and blow a headgasket
Thanks for your help:beer chug:
Cúl-Báire
Brisbane, QLD
AUII XR8 Ute & BAII XR6
hi there
My VT runs under half; with a new radiator, water pump, thermostat, piping and cap.
stevoss
newy
s2 vt ss
you need a thermostat otherwise your car will EVENTUALLY boil, the thermostat as well as circulating coolant also allows the stop of flow which in turn stops heat soak of the whole cooling system.
to get an exact reading of water temp hold mode and up on the dash controls for 5 sec while starting the car this allows the car to go into diagnostics which has a digital readout of the temp gauge.
11gothevt11
99 VT Sedan
Macanic told me i don't need a thermostat
I thought they are used only to open up when water is hot
Not having thermosat can make my car boil???
:beer chug:
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Thermostats are there for a reason, so it's a good idea the keep it in. I think the engineers who design these cars would know a little more than your mechanic.
11gothevt11
99 VT Sedan
i agree with you
But is the thermostat only so the car doesn't run to cold ????
:beer chug:
accentstencil
71
i agree with you
:beer chug:
Basically yes. Also, in winter when you need your heater you will have problems getting it hot.
11gothevt11
99 VT Sedan
not having a thermosat can make car boil????????????????????:beer chug:
skerik
Traralgon, Victoria
2011 VE Series 2 SS Thunder Ute
My VT runs about 85-89 degrees C.
It has been as high as 105 in city peak hour on a 35degree day.
