How in the hell does the bastard harmonic balancer come off?
Astranomical
Ecotec just kicked in yo
39
Dee Why, NSW
AH Astra (daily), VX Berlina, VN Calais, Mazda 626
Hi all, I need to replace the CAS in my VN Calais “Series 1.5” (Series II car with Series I engine). About a year ago I replaced the harmonic balancer with a new Powerbond one. When I removed the old one I used a puller from Supercheap and got the correct bolts and washers from Bunnings and had it out relatively easily after removing the bolt. However it seems the new balancer, even though it has the 3 holes, doesn’t have any threads to screw into. And there’s no way it will just pull off either. I’m now really starting to regret not doing both at the same time...
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
Probably need the correct puller however, I did remove one on a vp using a simple steering wheel puller and bent hook ends on the bolts to hook into the holes on the balancer
Is there enough room to use nuts and washers on the bolts ?
Astranomical
39
Dee Why, NSW
krusing
Melbourne, Bayside
A Bearing Puller will do the trick.
Immortality
Staff member
Sth Auck, NZ
MikeC
VQ Statesman
$241.21 !! " I’m now really starting to regret not doing both at the same time... "
losh1971
North Tas
VE Series I SS Ute
They used to be about $140 but everything Commodore has gone up a lot compared to 12 months ago, somethings have doubled in price. I have also noticed that the amount of Commodore parts for sale online have probably halved in the last 12 months. Spares Box in particular have really reduced the range of VR parts available over the last 12 months, so much so that the are far from the cheapest place to buy from like they used to be.
Immortality
Staff member
Sth Auck, NZ
It's the kind of part you try to beg, borrow or steal for the job rather than buy for the one-off occasion.
rambunctious
VZ Executive Wagon
