How much boost can my commodore take?
jakescicluna
VE sv6 S2
I have a 2013 sv6 ve series 2, I believe these are the details of the engine; HOLDEN COMMODORE SV6 VE -VE 3.6L PET LFX V6 24v DOHC VVT Direct Inj {210kW}. I was wondering if anyone knew how much boost the engine can take, and a relatively safe number to run the boost at. Thanks.
losh1971
North Tas
VE Series I SS Ute
Depends if you intercool or not. Are you going turbo or SC?
losh1971
North Tas
VE Series I SS Ute
Talk to Tonyz Turbo Garage, he will give you the right information and tell you your options.
07GTS
Australia
VEGTS BUILT BLOWN E85
may not matter boost wise it will be how far u can go on the stock direct injection before fuel runs out first, DI has a very small window for fueling
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Do it LT5 style, DI and port injection.
Ginger Beer
Dunnydoore
7 psi to start, then page up
Isaac_bowey
19
Ve sv6
You’re better off just getting an ss and supercharging it. Otherwise if you want a turbo 6 just get a Barra car
Shen Long
Roxby Downs
WH Caprice 5.7L
Capa do a supercharger kit for LFX motors - expect around 300rwkw with a cam & stock internals
if you start tinkering with the internals (pistons, valve springs etc) you can get more rwkw - but it won’t be cheap when compared to a V8
