VS series 3 v8 manual cruise (vt roller motor and ecu stock)
ok i worked mine out!, if you have the plug under the bonnet, just purchase the cruise module plug it in and install your cable. replace you indiactor stalk with the cruise one, plug in extra stalk plug , the extra plug was there as was the one under the bonnet (mine has a level 2 dash, no digital). pop your fuse box cover under your steering wheel, i cant remember which relay (probably says cruise!!) but you need a relay the same as the electric window relay installed there (you can test it with your electric window relay). if you are an auto you are done!!!, if a manual then find a spare plug near your clutch pedal and bridge it!!!, this is the clutch crusie cutoff, without bridging it , it does not work. only problem is, when you clutch with cruise on, car revs!!!, the you have to disengage it with stalk or brake pedal. to install properly you need to run this plug in to a switch you need to install behine the clutch pedal!! good luck all it was easy as hell!!!!!!
