remove a Quaddie?
some simple steps ...
remove aircleaner (and air tubes hanging off that)
remove accel cable from side link (it clips off)
remove any tubes/hoses going to carby body (most just pull of, some have a clamp)
remove choke tubes (one unscrews, the other pulls of the choke body)
remove fuel line at front (if original, unscrew fitting otherwise if fuel hose take that off)
undo 2 long front bolts (top of carb at front) and 2 rear nuts on manifold studs (down low at rear on throttle body)
should just lift Quaddie off manifold now (gasket might stick though)
