How to Replace VS Door Actuator with a VT Actuator
ephect
Donating Member
VS Acclaim V6
Thanks, but I just purchased a reasonable priced one on eBay.
Is it a reproduction or gen item? Curious how it looks, fits and holds up.
Immortality
Staff member
Sth Auck, NZ
I'm kicking myself I didn't pull a few out of a VS I scrapped a few years ago :(
But I did rescue a couple of actuators from a VH :)
Phillbert
Gold Coast
VS L67 Ute, VX SS
For future reference in the pic is 2 actuators, Left is VS, Right is VT on...
I will still check the short lead to Actuator on my VS Ute (Series 2 '98) to see if it's the same plug that goes into loom as the later ones.
NORTI
Radelaide
Wildtrak
my 97 Senator runs the VT setup. I suspect that a 98 will run VT as it was well into production by then.
Having A Break
Somewhere
Goggomobile
Did you specify RHF. There are 3 different applications. The p/n's seemed to change over the years, however, the RHF has a Green plastic rod. It is referred to as the 'Master'. The others are opaque white. Inside they are different except for the 2 rears. They are interchangeable between left and right (on rear). The RHF has a single micro-switch, whereas the LHF has two, and obviously a different sliding mechanism. The PCB's are also different. The front two have 5 input wires, although different pin assignments and designations (colours). Generally the RHF ends in *****865 and the LHF in *****866. The rears both have 3 input wires.
BlackVXGTS
Melbourne, SE
The one I just had delivered is the same as the one on the left (fortunately). Now just have to find out how to test it to make sure it works! Don't need it right away.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
so you bought a secondhand unit via Evilbay ?
