J
Jerka078
Guest
whant to know how to tune them ??
what makes them hard to start ???
Gas systems are notoriously had to start first thing as the gas comes to the converter as a liquid and had to be transformed into a gas, for this you need heat and that is why the converted is plumbed into your cooling system (now a heating system in this case), now obviously first thing your car is cold, therefore it produces very small amounts of gas, thus having to turn the car over more than normal to get the required amount of gas into your cylinders to start up, this is also the reason most gas cars notice a performance increase when the motor is warm.
I'm pretty happy with how easy it is to start on gas - need to crank it a few times but it's all good.
Get it tuned from the installer then modify the fuel system. That way the gas computer will reflect the changes to the fuel system - doesn't it?
howdy Its a LANDI fitted to a 95 Ford NF fairlane and the stepper motor has been replaced with a manualy adjustable power valve, just not sure wich is the sensitivity and idle adjustmentson the converter and how
How the f**k did you grave dig a 4 year old post?
...modify the fuel system...
