HSV suspension mounting difference?
LJW-SVZ
24
Leeton
VZ SVZ ute 6spd
So in the market for coilovers for my VF ute (2016 SSV), have settled on BC Racing BR series since they best suit my needs and budget. The question is though, that BC has 2 different BR options listed for the VF chassis. ZW-04-RN (Holden VF) and ZW-07-RN (HSV VF). Both are the same price, both appear to be exactly the same, but what I can’t figure out is why they would be different part numbers
HSVs being 99% the same basic architecture as the “standard” VF chassis, surely HSV shocks don’t mount any differently to standard equipment? I asked BC Racing directly on the difference and they couldn’t give me an answer. Does anyone know for a fact if they’re the same with just different spring rates or something like that?
I’m all but certain that HSV ones will mount just fine in my ute (ZW-07-RN are currently in stock, whereas ZW-04-RN are on 3 week backorder at time of writing). Thanks in advance
Pazzu
Canberra ACT
2012 VE S2 SS Thunder 2017 VF S2 SS
I don't have experience in pulling apart HSV or standard SS. Maybe asking the wreckers to confrim or anyone here to confrim. But my gut says unless someone is certain that the mounting is 100% the same, the 3 weekbackorder for a piece of mind is worth it. Saves you from mucking about shipping back and forth and having a car unavailable
RevNev
VF II SSV Redline Ute
There's no difference between Holden and HSV strut and shock mounts, they're exactly the same OEM Holden.
Given this BC mob don't differentiate between wagon necessity for stiffer rear springs, they don't differentiate between Redline's retaining large diameter sway bars and they're wrongly implying HSV mounts are different, they obviously haven't put much R&D into VF Commodore requirements beyond adjustable spring platforms for variable ride heights.
Unless someone's tracking their car or specifically wants the sharpest handling that'll be rough riding on the street, I try to steer them off racing coil overs as much as the novelty of adjustable ride heights is a good thing. Kings and Monroes will give you any ride heights you like, and they perform extremely well with good bang for your buck on a road car setup.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Maybe it's just a plug to stop the MRC from kicking in the speed limiter...?
LJW-SVZ
24
Leeton
VZ SVZ ute 6spd
Bit of a worry if BC Racing don't know the difference either.
I heard back from BC finally, and the only difference between the two sets of coils is the lower rear mount hole is a slightly different size between both sets. The regular one is 12.7mm, the hsv one is 14.7mm. That’s it, that’s all the difference. Apparently
RevNev
Rubbish, they're idiots!!
Immortality
Staff member
Sth Auck, NZ
Or charge more high end models.
