[SA] ICE 2 Step Street/Race Ignition Setup for a Holden 253-308 V8 with VN-VT EFI Heads.
Lewie
B Cast and flat topped!
Adelaide, SA
Very thirsty VT & VH project under way! YAY!!
ITEM: For sale is a brand new ICE 2 Step Street/Race Ignition Setup for a Holden 253-308 V8 with VN-VT EFI Heads. Part number 7842MC
I bought it a few years ago with the intention of fitting it to my project car but never got to it. Now it is no longer required. Setup was NEVER fitted to anything. Was removed from the box to check out but that is all. All in brand new, undamaged, perfect condition.
You can get this kit from the ICE Website ( 7 Amp Street / Race Series Ignition System - ICE Ignition ) for $1395
eBay has a similar setup with less ignition curves for $1430 ( ICE Ignition 7 AMP Street Race Ignition KIT Holden Carb V8 VN Heads SC IG IK0466 | eBay )
Save yourself over $400 right here!!
Specs from the ICE website are:
7842MC 7 Amp Street / Race Series Ignition Kit includes:
* ICE billet distributor featuring 6061 aircraft grade aluminium housing, hardened and precision ground 4130 chromoly shaft, high temperature upper roller bearing and oil impregnated sintered iron lower bush, triggering via Hall Effect vane sensor unaffected by dirt, moisture or vibration, generally avaiable with the option of small or large HEI style cap with plug wire retainer and spheroidal graphite iron, silicon impregnated bronze or treated steel distributor gear.
* 7 Amp 2 Step Street / Race digital ignition control featuring 80 preloaded, push button selectable ignition curves, two stage rpm limiter adjustable in 100rpm increments from 1000rpm to 10900rpm via push button switches, switchable dual table distributor and crank trigger spark programs and dedicated tach output.
* High voltage ICE Pro Series Race Coil.
* 9mm Pro 100 Series plug wire kit to suit your engine including number markers.
LOCATION: South Australia Northern Suburbs (Munno Para)
CONDITION: New
PRICE: $950 neg
DELIVERY/PICK UP INFORMATION: Prefer pickup but can negotiate postage or delivery at your expense
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer
CONTACT DETAILS: [email protected], PM, 0414729212
Setup is advertised elsewhere.
