awesome work dude
can you tell me exactly where you got the dome lights from?
i want to get some blue ones for myself!
the ones i have bought do not work for some reason.
Hey,
Umm with the lights what sort of lighting system do you have?
If you have the sunnies holder like me the globes are called bayonets. With the bayonets they are quite hard to find, even on ebay. So what i did was i bought a kit and wrapped red cellafane around it, however you spell it. See if you put blue cella around your normal bayonet it will burn through it and could cause a melt or fire hazard. So buy a led kit like this and then wrap blue cella around the led kit in the lighting system
1pc BA9S 1895 T4W Bayonet 12 High Power LED (White) PCB - eBay LED, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 01-Jul-09 13:10:32 AEST).
So see the first big SMD chip? That's what i have in my sunny holder, but 2 of them, one on each side.
I bought something like this off ebay
2 x Blue LED Side Light Bulbs T4W Bayonet BA9S 24V - eBay Other Lights, Indicators, Lights, Indicators, Car Parts, Accessories, Cars, Bikes, Boats. (end time 26-Jun-09 20:24:37 AEST)
and these didn't fit in yet they were the same size, i don't know why but this is how i did my lights.
Also you may need to reverse polarity, that means you may need to de-solder the wires and re-solder the green and red wires. If so ill take a photo to show you how my wires are on top of the sunny holder.
But some Holdens have the lighting kit in the middle of the cabin, above the console lid. Those lights are a festoon base. I think they are either 36mm or 42mm off the top of my head. Then go on ebay and type in "blue festoon" and that will give you some festoon globes to fit your light.
One more thing whilst im here, if you do have the sunny holder thing at the front you will have rear side lights above your passenger doors, they are 36mm festoons.
Hope that helps mate, if not ill take out my sunny holder and show you the wiring kit above the sunny holder. The only problem about these led kits are the wires though, if you see the bayonet light in this
you need to put that into your bayonet base holder and then if you can see the little wire that comes off it with a little plug, you then need to plug the big SMD led to that bayonet wire which then makes the LED work. Also don't wrap too much cella around the led as this sort of holds the light in too much and then wont bright up the cabin too much. So wrap the cella around the led about 2-3 layers or until you have your desired result.
Good luck, any questions just ask me.
