ROSSRAY
change wiper motor for a new one had same problem wont retun to park position $100 through holden fault is high resistance should be 0 or near 0 ohms if you use a multimeter (two wire go to park switch on wiper motor) in low speed or high speed and you don t get a 0 k reading you need a new motor i tried one from the wrecker and it had the same problem, after fitting a new motor fixed 25/11/2013.low speed works, high speed works, but when on intermittent it acts as if it is on low speed. I have checked the two wiper relays and one wiper fuse in the engine bay fuse box, pulled the wiper switch out (which seemed to be ok), opened it up, cleaned it and put it back but it is still doing the same thing. I have also checked other fuses in the engine bay fuse box and the rear battery fuse box and they all seem ok.
Any ideas?
