So does adding a Cam change any of the responses given in this thread? ie. Due to Cams, fuel must be kept at higher level than a standard VF/VE
Not in terms of amount of fuel in the tank… the pump will still pump fuel at the flow rate and pressure it’s designed to deliver even with the low fuel light on…
However, performance upgrades raise a different question in that what rate of fuel flow does the modified motor require? followed by yne related question can tne existing system cope with the newer higher flow rates?
After all, mods put a higher fuel flow requirement on the fuel system since the engine can produce much more power than standard. And that’s because the crux of all mods is to get more air into the engine as you can then squirt more fuel to produce more power. But such may require upgrades to the fuel pump flow rates, pipe sizing, injector flow rates and such. The aim would be to be able to supply the required fuel flow without hitting any limits. Limits tend to be seen when the duty cycle for either the fuel pump or injectors are maxed. Pipe sizing also has a play in it as a fire hose can carry more water then a small thin garden hose… If the duty cycle is at or near 100% at WOT, then something’s gotta give and that is usually loss on combustion control and mixtures going go dangerously lean which can be very bad for the engines (holes in pistons bad).
I don’t know if a cam upgrade would put large enough extra load on the fuel system where it can’t cope but usually the kits don’t include new p7 maps or injectors so one would think it’s ok. But it does get a lot more complex when adding a supercharger where fuel system components can be upgraded. Your tuner should be able to advise…
Just don’t accept bullshite concept that one needs to have at least a half full tank to have real performance. Never heard such crap about fuel tank levels from makes such as Ferrari, Porsche or even GM (with their new corvette)
Good engineering will ensure all parts of the vehicle can perform as expected, including running safely with the low fuel light on
