K-BAGZ
De Plane! De Plane!
- Dec 22, 2012
- 524
- 12
- 0
- Location
- Far North QLD
- VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Model: Z Series Clubsport R8
Year: 2005
Colour: Impulse Blue
Kms: 125,XXXkm.
Engine: 6.0L LS2. 330rwkW. Built and tuned by PowerTorque Engines. 236/242 .615/.620 112 LSA Iskenderian camshaft. Bigger valve springs. Alloy OTR intake. Custom VCM Suite tune. Ported 243 cylinder heads. Pistons machined down for valve clearance. LS7 single plate clutch w/ billet flywheel and slave cylinder and braided clutch line. Powerbond 25% under driven harmonic balancer. High volume oil pump. ARP rod bolt kit. Double row timing chain kit. Comp Cams lifters and guides.
Exhaust: HPC coated Pacemaker 4-1 extractors. High flow cats. XForce full twin 3in stainless cat back system with two mufflers.
Transmission: Rebuilt HSV T56. Street Rip shifter. Braided clutch line.
Differential: Standard HSV 3.46:1. Stronger axle shafts. Harrop differential cover.
Suspension: Pedders XA coilovers. Camber/toe kit.
Wheels: 20in VE E1 GTS staggered.
Interior: Leathery. 6500K White LED SMD lights for Map lights, rear courtesy lights, centre console, glove box and footwells.
Stereo: Alpine Double DIN headunit. Splits in front. 6x9 in rear. Apline 4 channel PDX 4.100 amp. Apline PDX 1.1000 mono block amp. 2 x 12 Apline Type R subs. 2 Farad Power Capacitor. Pioneer DVD player on roof.
Exterior: Clubsportness. 6500K White LED SMD parker lights. Philips Diamond Vision 5000K H11 Low beam and H3 foglights. Philips White Vision 4000K H9 high beam. LED SMD front, side and rear indicators. LED SMD stop/tail, reverse and number plate lights. VZ Calais tail lights.
Other mods: Dashmat. Sunshade. Autometer Pro Lite shift light on cluster. Auto meter fuel pressure gauge on fuel rail. Tridon lever radiator cap. HSV valve caps. Spark plug lead thermal insulators. Alloy caps for brake, clutch, engine oil filler and power steering. Alloy power steering reservoir cover. Alloy A/C cap, engine oil dipstick cover, overflow and washer bottle cap. HSV tyre pressure gauge. Chrome wheel nut covers. Optima Bluetop battery. Rear black venetians.
Future mods: TBA
25/8/15 - Replaced boot struts and installed Calais tail lights. Heat mat fitted around battery.
2/9/15 - Replaced main and AC belt tensioners. Replaced main belt.
4/9/15 - Rear venetians fitted. OTR air filter cleaned and oiled.
8/9/15 - Replaced AC belt and all tensioner and idler pulleys.
Now for pictures when I first picked her up..
First mods were a dashmat, sunshade and a lever radiator cap.
Year: 2005
Kms: 125,XXXkm.
Future mods: TBA
