L98 manual cam
L98Cobra
50
Melb
VZ 6.0 M6
G'day, I have a replica AC Cobra with a stock (untuned) L98 and T56 with 3.7 rear end (S15 200SX). Tri-Y headers with 1 7/8" primaries into a 2.5" system with X-pipe.
The gearbox is out for a mid shift conversion and I'm going for a tune and maybe a cam.
Looking for a lumpy idle and good even torque curve mainly for street use and the odd track day. The car weighs around 1100kg so it needs good manners.
Top of my list is a VCM480. What supporting mods should I do? Trunion upgrade, double valve springs? Any other suggestions? TIA.
losh1971
North Tas
VE Series I SS Ute
Trunnions, yes, always a good idea but I don't think you need double springs, just get some Pac Racing springs from Rev High.
You will probably want a better clutch than stock or it will likely slip.
L98Cobra
50
Melb
VZ 6.0 M6
Thanks. I forgot to mention factory LS7 clutch.
L98Cobra
50
Melb
VZ 6.0 M6
And what's your opinion on the VCM480 for my scenario? Rev High in Hallam is close by, thanks!
losh1971
North Tas
VE Series I SS Ute
Choose your exhaust wisely. Many buy an X Force but they sound pretty terrible.
L98Cobra
50
Melb
VZ 6.0 M6
Exhaust is all custom 2.5". Nothing available off the shelf as these cars are 100% hand built and they're all a little different.
losh1971
North Tas
VE Series I SS Ute
Upgrade your lifters to LS7 ones as well.
losh1971
North Tas
VE Series I SS Ute
Ahhh, now I understand you have a Cobra, fibreglass body, but with a VZ engine and driveline? I was thinking you mocked up a VZ to look like the old Ford Cobra of the 70s we used to see on the streets.
L98Cobra
50
Melb
VZ 6.0 M6
Yeah sorry. And yes VZ series II engine. New from Ballarat Holden delivered on a crate for something silly like $3500 for the long motor.
losh1971
North Tas
VE Series I SS Ute
$3,500 for a 6L crate engine? That's a bargain. It's more than that in parts alone to rebuild one
