Lazarus
heyitsEnricoPallazzo
Big block Alloytec
VZ A4 Saloon
It's alive....it's alive....
undersuspicion
Now That's How We Roll!
35
Vy SV8 Series 2
lol nice mate.
Big block Alloytec
VZ A4 Saloon
Go to the wreckers and get a cut cluster plug (VY or VZ).
Release one of the wire terminals. You will need to lengthen the wire so it reaches the BCM.
Rip out your cluster.
Connect new terminal to #3. This terminal is vacant.
Connect other end to BCM plug X4, terminal #22 (white/green). I used a scotchlok cause I'm lazy.
Works well. Although does light up when the BCM activates the interior lights (e.g. unlocking doors). Big deal!
All terminals mentioned are clearly marked on connectors.
Cluster connector pic below.
Why Holden decided not to wire the door ajar warning I don't know.
304runner
( .Y. )
40
Central Coast NSW
VR 5.0 Ute & a 4runner with a VS SS trasplant
What exactly did you do????
[edit] Wait I see...
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
Four years I've been staring at that instrument panel and never realised that warning light symbol was there.
Good work.
Torquative
Sports Economy
VE SV6 3.6L SIDI 6sp
Im gonna go out and check now, looks like I have a task for next weekend :)
morphix
Cardiff, NSW
2004 VZ SV6 5-Speed Auto
so just to confirm this works for the stock VZ SV6 cluster too? appears you have the 3 window cluster?
Big block Alloytec
VZ A4 Saloon
Well if terminal pin 3 on the cluster plug is vacant and you have the door ajar warning fitted I see no reason why not.
From memory my exec cluster had the lamp fitted.
Phyco
Alloytec and Proud
WA
06 VZ Acclaim Sedan
This is totally an awesome idea, I just checked and my WL Cluster has it too - definitely doing it next month when I get holidays!
