da_warped_1
- Nov 11, 2009
- 19
- 0
- 0
- N/A
I found coolant leaking from underneath my radiator somewhere, not sure what's the cause or where the leak is. The coolant reservoir was empty and the engine was slightly low on coolant.
Im removing the radiator to find the source of the leak, however before removing the auto transmission lines, do i need to plug up the lines when i remove the quick connect fittings and if so what do people use?
Cheers!
Cheers!
