You sir, are a dumbass. Removing your springs would have the same effect.
that wasn't very nice :supersad:
i'll have you know that the previous owner put the springs in without changing (or dodgying up) the rear bumpstops, and i am sourcing some shortened ones to try and get some useable suspension travel in the rear.
and if i was to take the springs out, it wouldn't have the same effect at all as my problemmed suspension at the moment, as less force would be needed to compress the bumpstops as there would be no other suspension components to take the load (springs).
to the OP, lows would be as low as i would go if i was using my ute for work, i would nearly contemplate going to standard height, maybe even with a stiffer spring rate depending on the weight that you are carrying regularly.
