Ls1 on E85
Adz2332
39
R33 Skyline LS1
Afternoon all,
I have a track car that im in the middle of building a LS1 5.7l for.
Im looking to run it on E85. have many people done this?
What injectors did you use?
Did you change anything else?
Mods currently are
Ported, polished and decked heads .020 thou
double pack Valve springs
arp head studs
HD valve springs
HD pushrods
ARP cam bolts
Cam 227/239 @.050 Valve lift int .613 ext .620
Ls7 Lifters and buckets
Head gasket, water pump gasket
Full custom fuel set up and fuel reg
Haltech computer
stock intake for now but considering a change as well as changing the fuel rail when i work out the injectors needed etc
any advice would be great
Sandman
Challenge Accepted
Too many
Can't help you with injectors or anything, but on the chassis side of things, you'd want to upgrade the fuel pump, in tank fuel line and the soft lines which go from the tank to the hard lines under the car. All these lines won't be rated for E85 and are generally cheap to upgrade too. Assuming you're running a stock tank the the 33, I gather anyway.
Adz2332
39
R33 Skyline LS1
thanks mate, should have said.
I ran E85 on my RB25. have a full system set up for it and lines etc.
