LS1 spark plug gaps?
Cava454
35
Box
VR SS, VZ SS
Ngktr6 is what I use and my tuner recommended. Uses it on all his cars from stock to 550rwkw.
Don't need that fancy platinum crap. $50 got me a hole set from repco...
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
Thanks for that man, always wondered if worth going expensive or not
Sent from my HTC ARIA using Tapatalk II.IV
Grennan
Slayer of Stupid Threads
Glen Waverley, Victoria
VE SSV G8 Sportswagon
From memory you can use the same plugs as the L67 which are standards. Think they are BPR6EFS-13 or something.
Im of the opinion no plug should remain in the block for 100,000km. Platinum or not. Ive got them in my car at the moment, only because I get them at cost.
03VYSS
34
VY Ute SS 5.7 M6
Pretty good price. Might have to check my local repco as well
402ls1
46
Vx ss Holden commodore 5.7
Hi I have a ls1 402ci supercharger running 7psi what is the spark plug gap ngk tr6
402ls1
46
hi mate I've got 402ci ls1 supercharger running 7psi what is the spark plug gap thanks
monstar
Naturally as-pirated
depths of Hays Inlet
facebook.com
Peugeot 207 GTi
I hope you are sorted by now?
Zeke Topanaga
64
SEQ
HX Sandman p van 308 4speed
My book says VT Gen 3 1.5mm gap.
VY 1.3mm gap
VY series 2 and from then on 1.1MM gap.
I have used the NGK Laser Platinum at $17 each and the AC Delco were original and I went for AC again next at $11.53 each bought from the Holden dealer.
You can use just the standard copper core type plugs, if you like changing plugs every 20,000km f that when I do 50,000km a year, I have better things to do than change plugs that are a bastard to change.
Why the difference in gaps in the Gen 3's must be different coils ? the speck is all over the place as to dates, so it just does not stop on one date and then the smaller gap start and that is because of all the different model types don't start or stop the same time with Monaro and crew cabs holding the older spec.
Plugs can last years in a engine and some do 160,000km no problems.
It's not the 1980's now with plugs only lasting around 12,000km with Bosh Champion crap, I got 20,000km out of NGK back then, but had to pull them out and clean them and re gap at around 10,000km.
Mookie01
Guest
50
Southport
VS commodore executive series 2
VY 1.3mm gap
Hi yeah thanks for that VY gen 3 gap ,
just a heads up I bought on eBay $25 including postage for 8 irridium spark plugs AC delco on eBay , now they were from China however all AC delco is an American brand yet they make them in China as that is where the cheap production is ,
No you have not mis -read what I said that’s right 8 irridium spark plugs including postage for $25
