engines may be in spec but on the border line, you may have a bore size thats at its upper limits still within tolerance , and the piston fitted to that bore at a lowest tolerance size, so you have a larger size bore and a smaller sized piston that been fitted , all within manufactures specs, add the modern low friction short skirt piston and that's the main difference between old 70-80s old pushrod v8s, the short skirt pistons will rock more in a oversized bore, that's the price for low friction and increased fuel mpg and more hp, as they say everything's a tradeoff
