LSA blow off valve sound
Jarvo505
VF GTS
Hi, recently purchased a VF GTS and have noticed under hard acceleration around 5,000rpm there is a choof noise that sounds like a blow off valve.
Is this normal or possibly a bypass valve issue?
Thanks.
Deuce
Super Stock
'94 VR SS V8
I cannot say I know the LSA well enough, but it should have a bypass valve which will open when you are off the throttle.
Possibly after you lift after a squirt on the gas, manifold pressure may release backwards through the bypass towards the airbox.
But as I said, I don't know an LSA so cannot confirm.
Jarvo505
VF GTS
Turns out this seems to be the bi-modal exhaust valve closing, then opening again at higher rpm.
