Lumina totally lost power. Any ideas
Zarna
39
Burnie
Vx
Hi guys and goals I have a 2002 lumina that's decided it wants to play games with me. Started with random lights popping up on my dash then I lost power to the dash and now the car is dead. No power to the dash or ignition or anything.
Grimes
NSW
VS Commodore Series II Ute
Start by checking all the relevant fuses, under the bonnet and in the cabin.
AB 1000
19
Queensland
2003 vy manual ute and 1998 VS S pac ute
Could it be dead battery? Sounds like the alternator.
Grimes
NSW
Possible, but for a battery to just go black it has to have failed internally which is becoming a rare event in modern batteries. If the alternator has started going haywire, the battery should still at least be giving enough voltage to light a dash bulb particularly given the dash died before the engine did. If a fuse has blown somewhere, the next step will be to find out why and what else may have been damaged.
AB 1000
19
Queensland
Yeah true you are correct it sounded like that to me.
Zarna
39
Burnie
Vx
Yeah I’ve checked fuses, terminals.
lout
60
Langwarrin Victoria
Grimes
NSW
What systems were lost and in what order? Was the engine running or starter still turning after the first loss of dash power?
BlackVXGTS
Melbourne, SE
Did you check the fusible links, particularly FJ, the main 60amp fusible link.
