Magnussen noise
kleanphil
G.C.
VF SS-V SII Sportwagon
I have a noise in my motor , i was initially told it was the charger then told its a lifter but i'm not convinced , is this movement normal for a Magnussen
Immortality
Staff member
Sth Auck, NZ
No. The coupling in the blower is stuffed and needs replacement.
kleanphil
G.C.
ye i sorta figured it wasn't right , i got another opinion today and they pointed to the charger to be looked at before considering the lifters.
The problem is the mechanics i use are one of a only a couple high performance joints here and its awkward to try and argue the point
Hq King
64
Taupo NZ
VF SS 2 Magnum
Not real sure but I understand it is a common fault and some people are replacing them with solid couplings not saying it is a good idea but worth looking into ?
Immortality
Staff member
Sth Auck, NZ
The blower is a lot easier to R & R so I'd tell them to start there. It's your money after all and the customer is always right.....
Immortality
Staff member
Sth Auck, NZ
Not sure TBH, I do know some blowers have issues with the couplers or the coupler design. I'm not familiar with this blower so can't comment but looking at the play it's definitely stuffed.
Hq King
64
Taupo NZ
VF SS 2 Magnum
Yes you are probably right and shouldn't have implied that it was a common fault with all blowers. Are they similar in design or do they very? And do the couplers have rubber in them which I am guessing to take the shock out of the rotor . Just trying to learn
shane_3800
35
places
vr commo
Honestly if it's awkward you need to find another mechanic. When I was running my work shop I made it a point not to make people awkward.... Maybe that's why I went broke but alas that's another story.
Skylarking
123
Downunder
Commodore Motorsport Edition
The principle should always be that the workshop that supplied and installed the mod should stand by it. The mod should operate with no issues for a reasonable time, else if you have problems you’re covered by either the sellers warranty or ACL statutory warranty :cool:
The fact you’ve already reasonably identified an issue with the supercharger, the only other thing to consider is whether the failure is normal considering how long since you had it installed.
Id think a supercharger should last as long as tne engine = decades and 100’s of 1000’s of kms... not a few years...
If it’s a fault with the charger your workshop installed, it’s something that should be covered under your statutory warranty, so don’t let awkward get in the way else it may cost you $1000’s to fix a product defect :eek:
