Manual conversion
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by dans_vz, Oct 26, 2008.
  1. dans_vz
    dans_vz Member
    Albury/Wodonga
    2011 VE II CalaisV SWagon & 92 VP II Calais V8 5sp
    Hi guys,
    Im considering converting my VZ from auto to manual.
    I have done this before with my old VP and a VN and just wondering if anyone knows if it would be much different in a VZ?
    Would I need to get a different computer in the VZ or can Holden flash the old one? What other wiring would I need to change?
    Also are the cross members different in VZ manual and autos?
    Thanks guys...
  2. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    hey, ive been looking into the aswell,
    the vz's use a single pedal box for each pedal, so you will need the new brake and clutch pedal. there is also 2 wires with a connector around the area of where the clutch pedal goes so im assuming that will be the plug for the clutch switch.
    they use a common bolt layout and crank bolt between the auto and manual
    you will need the interior parts obviously
    you will need to remove the transmission control module behind the passengers kick panel
    im guessing you will need the manual tail shaft of the equivalent body style
    im not sure about the reverse sensor light switch and speed sensor, speed sensor may be the same plug
    if you get it all together and it actually starts and runs, you will need to get it to holden and so the ecu/bcm/dash cluster and possibly abs module changed to a manual tune/settings
