V
Vzniko
Guest
Hi everyone,
Had posted a thread a few months ago about the misfiring issues I was experiencing on a VZ (dual fuel) commodore. Powertrain error
would come up also every now and then,
with codes
PO300- Multicylinder misfire
PO303- Cylinder 3 misfire
After a spending tons of money on dodgy mechanics, wrongly diagnosing it, I bought a repair manual and tried to do some things myself
and see where it takes me.
Anyway, I have replaced all the coil packs (one mechanic replaced 1 so I decided to do the rest myself). Fitted new NGK platinum plugs, and I did a compression test just the other day and all came up clear (compression on all cylinders was 13.5atm) and builds up very quick, which eliminated any problem with internals like valves etc.
I am starting to think that it could be electronic related, PCM or ECU, however the repair manual said if ECU faulty would cause glitches on the computer, and so far have not experience any of that.
I am getting pretty tired of this game, and I am sick of repairing this car, I have spend so much money and energy and I am still back to where I have started.
Any thoughts of what I should do next - I really do not want to take it to Holden, They will have a look - Clear the codes - charge me a few hundred bucks and go by the process of elimination like everyone else, costing me hundreds along the way.....
REGARDS
P.S car has done 160,000 and problem evident on both LPG and petrol so I have no reason to think its LPG related only.
with codes
REGARDS
