jpetrou
- Sep 3, 2005
- 92
- 3
- 8
- Age
- 58
- Location
- Adelaide
- VK SL EFI/ Monaro CV8
Hi all, I need some help in regards to the front bumper on my Monaro CV8. Being similar to the VT design, I figured someone out there might be able to help.
A few months back, I accidentally got the front bumper "hooked" on a car park concrete block (the ones that stop you from going too far forward or back). Anyway one of the bolts/pins that hold these concrete blocks down was sticking out way above the height of the block and subsequently hooked under the front bar. Without realising this, when I backed out, the bumper was pulled away from the car. Whilst the damage was minimal, the bumper cracked underneath and required a brand new bar.
I took it to my local panel shop whom I trust and has always done good work in the past for me. They had trouble getting a decent brand new genuine front bar from Holden, as the first two were either damaged or poorly finished. After a few weeks Holden finally sent a bumper that was of a decent quality and subsequently was painted and fitted.
This is where the dramas started, they couldn't get the front corners to align properly and despite their best efforts they got it to a stage where it wasnt perfect but passable. Plus I got tired of not having my car at home after nearly a month.
They checked the body alignments and all the mounting areas for correct measurements and found that all the measurements were spot on.
After driving it for a few short drives and the weather warming up, I noticed last weekend that the gaps have gotten worse and now they stick out like the proverbial.
I took it back to the panel shop and the owner agreed it was worse and it was unacceptable. He said that he will look into it and contact Holden. He is totally stumped, as he has never had this issue before.
He doesnt want to mess around with bending guards and panels to "fit the bumper", as he thinks there may be another quality control issue with their bars.
I have attached photos for your comments, my apologies for the long winded story.
Thank you in advance.
