losh1971
North Tas
VE Series I SS Ute
True and true. The Alpine units are more expensive and they are certainly not without their issues. If I could, I’d have the Alpine H/U but the Aerpro HVAC control. The Aerpro HVAC looks to me like it is simpler and easier to control. The Alpine is fancy and TBH, in my opinion, bloody stupid. I find it frustrating and it looks like a graduate got bored working at Alpine one day… and came up with that design while sniffing something. Good design (especially interfaces) should be simple for us to use. Have the flashy crap if u must but let me turn it off!
I actually suspect and I could be wrong but I reckon we might have seen a bad batch of Aerpro units on the market over the last year or so. I don't remember hearing about so many issues a few years ago, and yet there seems to be a lot more people experiencing problems with their Aerpro's in the last year or so.
Fu Manchu
WA.
You can have an Alpine unit. You don’t have to use the Alpine HVAC.
mtd
melbourne,VIC
VE S1 Calais V V8
:) Yeah Fu, realised my post was a bit 'misguided' after submission.
The emphasis was more my gripes with the Alpine HVAC. Yes, they're seperate.
That said, I doubt (but I don't know, never looked into it) I could have the Aerpro HVAC and Alpine units fit the way mine does - It nicely replaces the spot of the orig GM H/U and HVAC controls. Maybe it does!??? Further, probably have to futz around alot...
Moorman
Meadow Heights
Berlina
Can we suggest coming down to a specific head unit? I'll take your guidance on this. I want to spend about $300 - $350 - or $400 without installing costs. And I want the unit to be able to play videos. Any format.
mtd
melbourne,VIC
VE S1 Calais V V8
Sorry, have come back a bit late on this as I simply missed it. Maybe this is all in vain but here goes anyway.
I don't know of any reputable H/U that sells in this range WITH good integration into the current vehicle. If that is not important then there are plenty of units out there. I'd suggest ringing a car audio specialist and explaining your budget. They might be able to come up with a solution that is closer to your budget. Always ask the questions I mentioned before so you are well-aware of what you are getting/expecting and what you are not (getting).
It's nigh impossible to pinpoint a specific head unit for you because there are many 'stand-alone' head units available that would do the job. You have to be clearer on what you want. I'll take you through the process I took:
I wanted a head unit to replace my original GM one as I got frustrated with a simple 'Audio' input and 6-stacker CD. I wanted to play music from both my phone and my partner's phone as a minimum. My BT (hands free calls) just did not work any more. Holden had looked at the entire system multiple times and effectively gave up. I gave up my overhead DVD player as it was on its last legs, and my kids are no longer 'kids' (therefore I needed no integration with this, but I could have got integration with a new Alpine DVD if needed - I didn't - but can always upgrade later anyway).
I did NOT want a 'dumb' unit. I wanted integration with my current steering wheel controls, and I wanted integration with my HVAC. [Note: I could have gone with a different brand HVAC setup but decided I wanted it all the same - my choice].
I also wanted a reverse camera. I did NOT (at the time) require my speakers to be replaced, I was happy with stock standard ones (I have since replaced them because of water leaks/corrosion problems since fixed).
Generally, I wanted the new H/U to 'work' with my current vehicle. I really like steering wheel controls (especially for long trips) for basic functions. I wanted a DAB radio and Apple/CarPlay/Android but could have done without about 40% of the extra functionality it comes with (easy, don't use it). If integration is not important to you, then it will be MUCH cheaper. Another note: Me calling 'stand-alone' head units 'dumb' is simply that they don't integrate with the current vehicle make/model controls. There are people who do NOT want integration - for a few very valid reasons. They want a stand-alone system and they pay for the build-quality/sound/ease-of-use/features etc, but NOT for specific vehicle integration. This is entirely valid. You have to know what you want, and go find it.
I knew what I wanted (and didn't) and contacted a few specialists - and also researched online. I picked a place and they both supplied and fitted it. I did think about fitting it myself but decided if i'm going to pay for a reasonable unit (and the thought of integration) then I might as well not skimp on fitting. I'm glad I got it fitted with hind sight.
You've already specified a requirement to play vids. That's good. Now think about the rest of your requirements.
You - Short-sighted, age/disability-related issues? (human interface to unit)
Vehicle - Berlina. What's my car got, what does it need. What can I leverage off?
HVAC integration - important? Does my HVAC work correctly now?
Speakers - replacement? Currently OK, or want different sound? Do you need to do extra with VE doors? What's the cost $$$?
Min unit functionality? Software/ Hardware.
DAB (and others)? Do I need better antenna? Will stock H/U ant be OK?
Future requirements? Any? AKA - I don't need this now, but might/will in the future...
Fu Manchu
WA.
Fu Manchu
WA.
losh1971
North Tas
VE Series I SS Ute
A Pioneer double din start at about $300. $400-$450 or so should get you android aswell. From the cheaper end of the market Pioneer have the best sound quality in my experience. Autobarn are as cheap as anywhere.
Moorman
Meadow Heights
Berlina
Thanks you guys. Got it. I'm very appreciative for your help. Will get on to it. And yes I'll get someone who knows what they're doing. Thanks so much. Really.
Thank you!
