its nothing against oztrack at all, steve was very good and willing to help or try and fix any concerns i had. i had an issue with the gearbox when using manual shift after i got the cam. when i was downshifting, every now and then it wouldnt shift down a gear for about a second or so, then it would shift and bite hard sorta throwing me forward. steve had a go at fixing it and we thought it had been fixed, but as is usually the case, not long after i left on the same day, it was doing it again.
so i took it to CHE and got a retune. the odd thing about it was, the first run on their dyno i got 283rwkw, after getting 305 on oztracks dyno, they are both dynodynamics dynos. after they retuned i was up to 294rwkw. the gearbox is a bit better, it still has the same issue occasionally but it isnt as bad as it used to be.
as i said earlier, i am not having a go at oztrack at all, i just felt at the time it was worth giving someone else a shot at fixing the problem.
oh and im running the stealth 2 cam wogboyz
