i have not had any running issues while its been there
idles fine and throttle is responsive...
that basically where the provision was for it to go in the piping i got off ebay from a fella who had it there.(still needed to modify it heaps as i have a bigger cooler than the one that came with it.)
i could when i bored move it to the cold side of the piping to see if its any better.
i backed out a plug today to see overall condition on them(new when turbo went on) and they are a bit sooty/matt black around the base of the plug and a lightish color on the earth hook.
matched it up to my spark plug diagnosis chart close as i could and saying "Can be caused by many different conditions. Carbon deposits build up when the plug fails to fire correctly and burn them off. Air/fuel mixture too rich, choke stuck on, electrical problem, extended periods of low speed driving, plug heat range too cold. All should be investigated" sourced from here
Spark Plug Diagnosis 2nd one down(fouling) but not that bad that sook all over plug(base of thread on the ridge)
wasnt the nice light tanned color as i should be expecting.
was thinking maybe its the AFM measuring warmer air and then when i get to TB through cooler it would be more dense meaning a leaner mix not Rich(rich causing soot)
your thoughts??
