No power to cooling fan relay terminals
inkdsmithy
New Zealand
VE Berlina 3.8
Hey guys so I'm having problems with vy fans not working ,Ive checked thermostat an replaced the sensor an Ive noticed when using electrical meter reader,put the probes into the terminals where the relay pins go in...no power ,there's power going to the other relay terminals but not the fan relays ,anyone know how to solve this cheers
BlackVXGTS
Melbourne, SE
Confirm whether you are posting about radiator fans or HVAC fans (Heating, Ventilation, Airconditioning).
If its radiator fans, do they turn on when you turn on the Airconditioning?
lout
60
Langwarrin Victoria
check the fuses
inkdsmithy
New Zealand
VE Berlina 3.8
Radiator fan...got it sorted was loose wiring under relay terminal
  • Like
Reactions: Lex
Fu Manchu
WA.
Probing terminals from the front of the pin with a multimeter probe will commonly cause loose terminals.
