Noisy trutrac differential
Robert Dawson
Gawler, South Australia
VE Commodore SS
Hi, this is my first post. I have recently bought a 2009 VE SS. It has had a truetrac differential with 4:11 gears fitted in 2016. It is noisy especially at about 80kmh. Can anyone give me some advice as to what I can do. I am new to Commodores.
Cheers,
Robert
mechanic
Australia
Commodore
What type of noise?
How do you know it’s the diff?
Tyre or bearing noise can sound very similar.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Cheers,
Robert
The (aftermarket) 4.11 ratio gear sets for the ZF diffs are known to be noisy.
Robert Dawson
VE Commodore SS
What type of noise?
It was diagnosed by my mechanic who knows modified commodores well. You can hear the noise all the time but louder at 80kmh. I did think of tyre noise at first.
Thanks
mechanic
Australia
Commodore
What type of noise?
Gear noise is usually a whine that comes only at certain speeds.
Bearing noise is there constantly.
The two are treated differently.
lmoengnr
Donating Member
Sunbury Vic.
What type of noise?
The 4.11 gearsets available for ZF diffs are inherently noisy...
Immortality
Staff member
Sth Auck, NZ
If your mechanic is familiar with modified Commodores, what was his suggestion?
If it is the gears than generally there isn't much you can do except maybe try a different oil.
07GTS
Australia
VEGTS BUILT BLOWN E85
did u keep the factory diff rubbers or upgrade to more solid ? even with my standard diff 3.7 i changed mine to street semisolid and got a heap of noise so went back to factory and silent again
vr304
Auckland, New Zealand
2007 ssv manual
If they used the motive brand diff gears they are noisy, got the diff rebuilt in my old vx ss with a true Trac and 3.9 gears new bearings etc and it was noisy right from the start due to the diff gears
