O2 Sensor advice
Richie66
WA
2004Gen3
I bought a 2004 GenIII 5.7L crate motor in early 2005 for a kit car I built. The engine harness I also ordered from Ballarat Holden at the time. The harness only ever had two 02 plugs on it, both flat 4-wire type - I connected these to the pre-cat side on the exhaust system. The car was set up to pass emissions etc and was licensed no problem. However, I have since read there should be four 02 plugs on a harness typically, two pre-cat, two-post cat, in addition the pre-cat plugs are supposed to be square type (not flat) to avoid an incorrect set up either side of the cat. Can anyone confirm I do have the correct harness / 02 sensor set up.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
I don't think the post cat oxy sensors are part of the engine harness.
lowandslow
NSW
V2 III Monaro
If it's passed rego and is running fine dont worry.
vr304
Auckland, New Zealand
2007 ssv manual
As above if it’s running fine no need to worry, I believe the post cat sensors only came in on the ve mate
mpower
5.7's only have 2.
Richie66
WA
2004Gen3
Thanks guys, reassuring to know there's nothing wrong
