Oil Leak behind harmonic balancer
scbh81
VRUUUM XU6 180 SC
42
St Kilda Victoria
HSV XU6 VTII 99
Hi guys please see attached video of an oil leak after the front crank seal was replaced. Do you think the mechanic stuffed it up? It's pretty bad .There is always a puddle after a days driving. Is there anywhere else it can leak from?
losh1971
North Tas
VE Series I SS Ute
Did he supply the seal? If yes then take it back. Sometimes seals can be faulty. That is assuming he greased the seal lip prior to fit the HB.
scbh81
VRUUUM XU6 180 SC
42
St Kilda Victoria
HSV XU6 VTII 99
No, I got the seal from Holden and gave it to him. He did say he ran into difficulty removing the harmonic balancer. I wonder if anything was stuffed up. What's the best way to approach this so that he doesn't say it's not his fault. Just need it fixed as he was the last person to touch that area.
greenacc
Searching for the billion
VE Berlina
That's bad, the seal is either broken or he forgot to put a new one in....
losh1971
North Tas
VE Series I SS Ute
Since you supplied the part he could say too bad. If i was approaching the bloke i would drop by his workshop and act like you don't know where the oil is leaking from. Say something like hey mate there seems to be oil leaking not sure why since you fitted a new seal. Don't go in guns blazing expecting him to wear it, don't let him get on the defensive even if it is his fault. Be calm and see if he will be sympathetic to your case.
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
Wondering are the seals know to have sealing issues after fitting.
How long after fitting did you notice the leak and do you have a payment receipt.
scbh81
VRUUUM XU6 180 SC
42
St Kilda Victoria
HSV XU6 VTII 99
Yes I do have all the receipts and invoices. The car got repaired about 6 weeks ago and but then I didn't drive it for 5 weeks and started driving this week and noticed it.
