Tim-dietrich
- Sep 13, 2014
- 109
- 1
- 18
- Location
- New Zealand
- ve ssv
Would you say it should be more leaner why do you think hes done it to make it safer? He specializes in these cars he mentioned something about the weather being stinking hot and hes compensated for when the temps drop and it gets cold would that be why its got that afr in top endI can't tell by that graph for a number of reasons mainly because it is not a real sensor log of pod vs OTR nor actually what your engine is making. ie the PC connected to the dyno calculates and graphs what your engine would make at 15.5°C and 0% humidity given the prevailing 25.2°C and 35% humidity.
But yes the benefit of an OTR is cooler air at speed, which is offset by hotter air in traffic - wider IAT variance - OTR vs pod temps may be +/- 20° for and against OTR vs stable and cool delivery via pod.
The 400lb Gorilla in the room is 12.0 AFR at peak RPM, like I mentioned previous that's leaving too much on the table for no good reason.
