Power Windows
woodbury
Yeppoon
2004 VZ Calais V6
Hi
Have a query... Power Windows.. 2 front windows work from console switches, 2 rear windows do not operate from console switches also the back switches on doors do not work, have checked child lock on console is in correct position. Would this be Master Switch in console needs replacing.
Thanks for any help.
seraphic06
Woodgrain Nut
Adelaide, SA
VZ Berlina Wagon, VS Caprice Series II 5.0
It probably came with the standard Executive standard of power front windows and manual back ones. Previous owner has probably replaced the door trims at some stage. Take one of the rear trims off to confirm.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
if it's a Calais like his ride, I'd be looking at the console switch area, according to the drawing the lock button is an isolator for the rears but only from switching from rear,
woodbury
Yeppoon
2004 VZ Calais V6
Great thanks for info and pic attached :)
woodbury
Yeppoon
2004 VZ Calais V6
Thanks have always worked.. 1 stopped then other side stopped :)
99notout
VZ Equip Wagon
I can tell you that if the switch on the rear door gets damaged or unplugged, then the front switches will NOT work. I found that out by accident while changing rear door solenoids and I had to plug the window switch back in to raise or lower the rear windows with the front switch. So just on the off chance, make sure the rear switches are still good!
