Power wire from central power windows??
zachy
b-town
vt berlina
Hey,
im looking for which wire is the 'power' wire from the central power windows harness.
I need to tap into a power source and this is the easiest source i can think of, just need to know which wire is power.
(headunit wires dont come out very far at all)
Thanks,
ephect
Donating Member
VS Acclaim V6
is this for a VT? what are you trying to achive?
if you are installing an aftermarket headunit dont feed off the power windows. Its only going to cause you problems down the track plus its on a circut breaker, so everytime you wind your windows up, it'll cut power to your stereo,
go and purchase an wiring adaptor that will extend the proper wires.
oska
vx custom 600RR
power to the window switch gets turned off after a couple of minutes if you want constant 12+ try the orange/black which is fed to your electric seat
oska
vx custom 600RR
yeah power is cut off under different conditions
1 minute if the door is opened without acc on
about 5 minutes with acc but not started
and you'll lose all the setting to the radio
power to everything is switched off, boot, light interior..... except the seats
