Powersteering pump wont budge
99notout
VZ Equip Wagon
Power steering pump slides out to the side after you have removed the mounting bolts through the pulley.
Simon Curnow
53
Willaston
VE SV6 2007
Thank you so much.
The bolt to the left of the two bolts that you can access via ps pump pully there is the bolt that is the issue.
Really taking off the ps pump pully off.
99notout
VZ Equip Wagon
Mate, you don't need to take the power steering pulley off. When you slide the power steering pump to the side, you can then easily remove the last bolt on the tensioner.
