Zeussy
SSM11K
- Dec 26, 2008
- 1,298
- 14
- 38
- Location
- Central Coast
- Gen-F Clubsport, Rodeo 2.8 TD 4x4
I've only had 1 drama with CAE personally (that was with my Torana at the start, long story). The LS1 stuff was fine, apart from the sump not quiet fitting the HR, but we knew that might be the case before we purchased it, but like i said, we really had no other choice. Having said that, all the extractors we have bought at work have never fitted without some sort of modification. There wiring looms are fantastic IMO. I've only really ever bought the looms, i tend to try and do everything else myself when doing an engine swap.
I'd stay with the leaf springs myself, for the simple fact that most 4 link aftermarket set ups are illegal for street use. The only style of 4 link that's legal is the OEM style found in HQ-HZ, Toranas, Commodores etc.
As for interior loom, we didn't use any of that in the HR, the CAE loom patches into the original body loom at the firewall plug so there is no need to use any of the Commodore loom. The HR is all standard inside (apart from autometer gauges) so the original loom needed to be retained, same as all the cars i've converted to EFI. ECU is in the glovebox, but you could mount it under the dash somewhere, provided you have the room.
Personally, i'd piss the fly by wire off, but that's just me.
Ahhk, sweet as. Will keep that in mind when it comes to the wiring.
Do you know why the 4 links are illegal for street use? Most of the mini-truckers are running around with 4 linked rear ends - engineered fine? Or was that before these new "chassis mod" laws came out? Probably will stay leaf springs in the end.
Will have to check out the space under the dash/glovebox area then make an informed decision!
I've heard you need to change the reluctor wheel to swap back to cable throttle? Sounds like a night mare?
