Pulley kit
Jeda
WN Caprice V
slower running alternator, slower running water pump, slower power steering, slower a/c pump, usually good if ur at 7k rpm all day
How much extra power does an underdriven pulley actually give you? Surely not enough to justify all the negatives.
Anthony .
NSW
1994 VR V6 Executive
Is power steering noticeably heavier?
07GTS
Australia
VEGTS BUILT BLOWN E85
power prob wouldnt be noticeable without a engine dyno to record in same situations, ive seen earlier VY with under drive and at idle the alternator wasnt charging needed just the little more rpm soon as u drive to get that working, VE may be different tho as its a smart alt, i havnt used one myself as i went the 10% overdrive for the blower so all mine spin faster, water pump u want faster rather then slower, alternator needs a minimum rpm for voltage and after that it dosnt matter they spin crazy high, power steering same deal as long as its enough for it to make pressure ur ok and after that it just bypasses the pressure not needed, if u have a low stock idle then alt and steering may be slightly affected
Anthony .
NSW
I think the aim to make the car more responsive and thus get into desired power band quicker rather than add power
