Mr Irony
- Dec 14, 2009
- 19
- 0
- 0
- VL Berlina
I recall reading that the reinforcement needed on the FE's was around the rear window. Early test models had problems with body flexing and the windows would pop out, so additional reinforcing was added prior to release. I don't think other rear end reinforcement was involved so I'm not sure that any FE's were available to the public with a "weak" rear end.
I believe some were sold. Undoubtedly recalled and repaired before very long too. It was a bit of talk about the place in the late fifties.
Re the S4's. I believe they only had sintered brake linings and wider drums, not discs and that the transmission was the standard 3 speed with heavier cluster gear and other bits. If I have my facts correct, until the S4 was released, the EH 179 could only be purchased as an automatic because the old three speeder from the EJ lacked the strength to live behind the 179.
Yeah, I know that. Though I'm not sure about that cluster gear. Main point is that the stories you hear so commonly from 'know it all' people today always include these incorrect 'facts'.
At the time the 179 was officially said to have been unavailable as a manual because of production limitations on the bigger engine. The EJ box, of course, was a one-piece iron casting for the bellhousing and main section, so it was never seen on an EH. Early, possibly all, EHs has noise in the gearbox, my dad's brand new 149 did for a certainty.
The first four speed wasn't released until early 1967 in the upgraded HR, at the same time as the 186X2 was replaced by the 186S and it was an Opel box, which showed itself to be very weak in normal use. It certainly wouldn't have held up to racing conditions. In fact, if you are talking about rare Holdens with the combination of options, then an HR 186S Premier with factory four speed would be a very rare animal indeed.
So too would an HR van with a 4-speed. Ever seen or heard of one of them?
My wife was working for a man who owned a carpet shop and needed a van, he wanted an HR but wanted a 4-speed and the dealer said he couldn't have one as they weren't optioned on HRs. They got me to write GM-H a letter pleading the case, including citing the fact that his driveway was steep and his '48 Buick was okay on it but the lower first gear of the 4-speed would be necessary for him to readily use an HR van.
He got it. Check around and see if you can find that one.
And has anyone mentioned the GT-X (is that what it was?) show car?
