RB 30 advice
ThatVLGuy
30
Bundaberg
Holden VL 5spd
First cylinder spark plug keeps popping out under load
Was thinking needs a heli coil kit.
Any other ideas as to why this could be happening
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
must of been striped
Reaper
Tells it like it is.
RG Z71 Colorado, 120 Prado , VDJ200, Vantage
Like lemmings jumping off a cliff, thats what you get from RB's
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
Alloy head - you need to 'crack the carbon' when removing the plugs. Undo them only about a quarter turn or so and retighten (a bit like tapping a thread using a tap or die). Repeat until you can unscrew the plug fully by hand without the socket drive. Don't back them out using a socket drive if they are resisting as you will remove the thread in the head along with the plug!
strgas
GRA = REAL HP
lol helicoil won't work, it will just end up falling inside the cylinder.
guess im doing something right if they havent fallen out over the 20+ years ive been using them .
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The trick to doing a helicoil on a spark plug hole is not to drill it all the way through, leave a lip so the helicoil bottoms out and can't screw into the cylinder.
Jxfwsf
Aus
commodore
Drill? Helicoil? .......
Must be using the cheap ****...
A proper helicoil™ kit uses a tap like this:
images
Runs through the existing thread and chases through with the insert thread, bugger all effort on an alloy head.
A custom made insert holder using a hollow rod, cross section drilled for the insert tang and a tapped end so a bolt can be threaded in to hold the tang.
When you give the rod a tap to break it off, hold it in place and successfully pop it back out isn't hard to make either.
Even for those deep cop heads... $0.50 of scrap material is an invaluable tool.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
I've only ever used the original style of helicoil kit with a drill and tap. And that was years ago, haven't had to use one in probably 20 years.
