ive just bought new seats coz my old one are torn down the drivers side. (hvent put them in yet, needing to fint the time. but a 6mm allan key is a perfect fit. had a look today and the drivers side is already loose :unsure: but the passanger side is not, so i can see its gona be hell. hopefully im not gona have to get the angle grinder out.
pulled the seats out the other day, easy to do, just sprayed a little wd-40 on the bolts, allen key and a ring spanner for leverage. they came out easy. just got to make the mounting brackets for my seats now.
this may sound dumb but there is a cheaper alternative to loctite, nailpolish, it will grip pretty much as good as loctite, im not sure if it will last as long though.. but if you are a tightass, do it the cheap way
but loctite is light 3 bucks for a bottle and silicon is like 4 bucks a tube and you waist it cause it dries up and you have to buy a new tube
loctite you only need a little bit and the bottle last a long time
so buy the time you buy a tube of silicon implants in a tube you ur better of buying loctite i recon
The way I did mine was to use a correct sized allen key and a screwdriver with the interchangeable bits.
Allen key in the bolt... slot the end of the allen key into the end of the screwdriver that holds the bits and use that for extra leverage.
But - the ring spanner that was mentioned earlier is a far better idea! Wish I thought of it - I broke a screwdriver in the process
It's a long job regardless. Then again I had to swap the rails from one driver's seat to another (height adjuster was shot) - now THAT was a prick of a job
All you need to do is put on the inside leg of S2 Vl Rails (and the bracket on pax side) onto VR/VS seats, VT has a different setup and needs brackets made...and theoretically egineering.
