holden#1 said:
sump plugs that tight! dry ice is one i shall have to remember. where do you purchase from?
That dry-ice trick is actually a really old school computer geek trick. In the olden days it wasn't uncommon for computer hard drives to just seize up. Putting them in the freezer overnight caused some components to shrink more than others, thus freeing the seized mechanism.
When they were defusing bombs in WWII they used cryoliquids, normally liquid oxygen, to 'freeze' the detonator, which made it shrink so they could remove it without the use of excessive force.
Same theory here, as for where to get the Dry-Ice from. A lot of those 'diet' companies who deliever frozen meals pack them with dry-ice to keep them frozen, if you know anyone who gets meals that way, ask them for it. Failing that, I guess places like BOC might stock it, if not they should be able to tell you where to get it.
Liquid nitrogen would also be a good way to do it. Just make sure that you don't put too much force on the bolt until it's come back to normal temperature, the extreem cold can make the metal brittle until it heats up again.
Remember the idea is to use the cold to make it shrink then come back to normal size. So freeze it, then have a go about 10 minutes later. I don't want you snapping the head off the bolt.
