replaced head gasket but wont start
redrags
Northern beachesNSW
walking
4 cyl carb mazda e2ooo van 98 model
fuel is getting to the cylinders there is spark the timing is perfect does anyone have suggestions of what it could be?
nemesis_adrasteia
better to reign in hell
longford, victoria
VR commodore HSV(without all the gay ****)
you need fuel, air, spark and compression. your engine isnt getting one of these.
youve tested the spark and fuel, so that only leaves you with 2 options.
has said above have you checked compression?
STEEV888
33
central coast
'95 200sx.
i commend people for not ripping on him for posting in the wrong section.
GOOD WORK MY FELLOW COMMODORIANS!
if you are 100% sure of the timing then compression sounds likely
is it even firing once or back firing ?
redrags
Northern beachesNSW
walking
the compression seems fine... it isnt kicking over or back firing
have you checked with a mazda forum??????
(am i the only one that thinks this is weird???)
this is weird because noone would talk to me in the mazda site about it and this site people actually reply
plus its the same basic theory anyway
maginoodle
vy series2 ss crewman
am guessing overhead cam, if so did you put a new timing chain on it? Chains can stretch and look lineed up correctly but actually be out by a cog. the only other thing if it has fuel is the dizzy timing close to being set properly?
redrags
Northern beachesNSW
walking
all the timing is perfect.. changed it a bunch of times. how can i dell if the timing belt is stretched?
naf33n
go
The Shire
Supercharged VU SS
did you check when cyclinder 1 is at top dead centre the valves are closed and nicely seated???
does it back fire or anything weird when cranking??? or just doesnt run??
redrags
Northern beachesNSW
walking
ok. so it looks like its the timing belt. its throwing out the timing quater of a turn one time then the next time it threw it out half a turn, does that sound like the timing belt
